XJ ( X351 ) 2009 - 2019
Weak low beams
Old Mar 9, 2021 | 10:25 AM
Johnny J's Avatar
Default Weak low beams
Johnny J , Yesterday 02:09 PM
I am helping a friend with his 1995 xjs 6 cylinder convertible, usa model. His problem is that his low beams are very dim while the high beams are normal. Apparently, the problem started when he was driving at night.
I don't have access to the vehicle yet so I'm doing troubleshooting by looking thru his manuals. I was originally told that the low beams didn't work at all but they do work, they are just very dim.
I originally thought the headlight control module was bad. Now, I'm not so sure. It's not a grounding problem as the high beams are bright as they should be and they share a common ground.
It's evident that something is pulling the voltage down to the lower beams. I was told to check fuses but then there is power to them.
Any help would be appreciated. Thanks.
Old Mar 9, 2021 | 11:12 AM
Mark SF's Avatar
Wrong forum. Try the XJS one.
F-Pace (X761) / C-X17
20
Mar 5, 2026 09:20 PM
mws
Aug 29, 2020 03:06 AM
ChilledJames
Oct 17, 2014 06:38 PM
Yappa634
Aug 21, 2014 07:02 PM
Oct 31, 2012 11:05 AM
