XJ ( X351 ) 2009 - 2019
What did you do to your X351 today?
Old Feb 18, 2020 | 03:12 PM
  #81
XJ8JR's Avatar
I've been wanting to get one of those for a while now. I think I'll finally pull the trigger soon.
Old Feb 25, 2020 | 12:13 PM
  #82
XJ8JR's Avatar
I can't believe this. After two weeks of silence, THE CLUNK has returned and its angry. It sounds like it's the sway bar bushings again but it doesn't sound like typical poly bushing noise. No squeaks or squishes, rather rattles and bangs. It sounds like what the regular rubber bushings are like when they're worn out. I think the marine grease might've just squeezed out. Looks like Mark SF was right. I'm about to get a tub of Energy Suspension grease from Amazon.
Old Feb 25, 2020 | 06:47 PM
  #83
Lightspeed's Avatar
Thats a shame, nothing worse than ongoing issues, i have some real sticky teflon grease made by quicksilver, but looking at the issue, maybe most greases will squeezed or worked out by movement by the sway bar inside the bushing.
That being said, its funny how you can fix one issue then the next component down the line fails as well and you end up doing one thing after another.
Old Feb 25, 2020 | 08:03 PM
  #84
XJ8JR's Avatar
Yeah, suspension issues have become my specialty and burden over the years. The roads around here just destroy these cars.
Old Feb 25, 2020 | 10:14 PM
  #85
Lightspeed's Avatar
Is there any way possible to drill the bushing and mount to thread in a small grease nipple for ongoing maintenance?
Probably a terrible suggestion.................
You could also dremel a thin and shallow channel from the hole in the bushing along the swaybar but not beyond the length of the bushing to provide a small reservior for the grease to help prevent it all from being squeezed out. Sounds drastic but seems logical if it is indeed the issue.
Old Feb 26, 2020 | 01:18 PM
  #86
XJ8JR's Avatar
I've read of that being done with some success but I think I would just end up ruining everything. Hopefully using the silicone Energy Suspension lube does the trick.
Old Feb 28, 2020 | 03:12 PM
  #87
Geoffrey Fake's Avatar
today .... I took a break after driving quite a few hundred miles non stop.
Old Feb 28, 2020 | 03:32 PM
  #88
OBC John's Avatar
Seems a bit extreme just for a smoke.
Nice XJ though so why not!
Old Mar 2, 2020 | 03:53 PM
  #89
XJ8JR's Avatar
So I tore into it yesterday AGAIN. Cleaned the old grease and teflon tape off the sway bar and the bushings, and applied the super thick super sticky Energy Suspension lube. So far so good. We'll see if it lasts more than 2 weeks this time.
Old Mar 12, 2020 | 01:22 PM
  #90
XJ8JR's Avatar
Well, the clunk is slowly returning. At this point, I really don't know what to do. I think I'm better off going back to the rubber bushings.
Old Mar 12, 2020 | 01:46 PM
  #91
XJsss's Avatar
I had my OEM bushings replaced over 50k ago and the clunk has not returned. and they are not lubricated.
Old Mar 12, 2020 | 01:59 PM
  #92
XJ8JR's Avatar
I really like the positive feel of the poly bushings but they just don't seem to be working for me.
Old Mar 12, 2020 | 06:58 PM
  #93
Lightspeed's Avatar
wondering which busings you used, were they the powerflex brand and which colour, purple or black?
Old Mar 12, 2020 | 10:09 PM
  #94
Nedoerr's Avatar
I had a front end clunk that was due to both the sway bar bushings and the upper control arm. First I swapped the sway bar bushings (also for poly), clunk dampened but didn’t go away. Then I changed the upper control arm, now clunk is gone.
Old Mar 13, 2020 | 09:17 AM
  #95
dmchao's Avatar
Sorry to hear XJ8JR, like you know I have the same powerflex bushings. It fixed my clunk and I do have some minor poly squeaking. I don't really care about that though. I might lube it up after I close on my new house next week and have more space to work on stuff. I have pretty much a new front suspension, my extended warranty covered replacement for torn boots for all components minus the upper shocks and rear shocks. Most people claim that warranties aren't worth it, in my case it's paid out about 5k above sticker.
Old Mar 13, 2020 | 11:29 AM
  #96
XJ8JR's Avatar
They're the Powerflex bushings listed further up the thread. They're black or a very dark purple perhaps.
I've been considering swapping out my upper control arms but the bushings and ball joints appear fine. But its on my radar. Might as well replace the shocks since they have to be removed anyway.
I don't see why it would be clunky for me and not for you. It must be something else in concert.
Old Mar 14, 2020 | 08:35 AM
  #97
Nedoerr's Avatar
For me it was primarily the bushings of the upper control arm. Though the ball joint boot was torn, the joint itself was fine. The bushings, however, were starting to crumble and presumably they would clunk around when I hit bumps in the road. The bushings were harder to diagnose until the arms were off.
Old Mar 16, 2020 | 04:23 PM
  #98
XJ8JR's Avatar
https://www.motorauthority.com/news/...r-xj-spy-shots
I'm not feeling it so far. It looks very bulky and boxy. However, it does look like it has some proper brake calipers behind the wheels.
Old Mar 20, 2020 | 11:27 AM
  #99
XJ8JR's Avatar
Now that I'm quarantined and working from home, I figure there's now plenty of time to do some heavy maintenance on the Jag. I've been pricing out replacements for the front upper control arms and front shocks. The struts themselves aren't too bad ($233 each) but when you throw in new springs, mounts, etc., it gets pricey. Maybe spark plugs is a better idea for now since the car can be down for multiple days.
Old Mar 21, 2020 | 09:35 AM
  #100
Lightspeed's Avatar
well I did not do this mod to my XJ today, but the purchase was made a few days ago on the bay( No affiliation with partslink) tell you what though I am hating the AUD exchange rate at the moment, and have stopped purchases from O/S due to it.
These are going to take a little work to get back into a condition acceptable to me ready for fitment and will require some dismantling to work out some dents and I will re finish to eradicate scuffs to bring back to new condition, will be a while I guess before delivery owing to C-19 screwing with border protections and delivery times.
Nice to have a set though.
