XJ ( X351 ) 2009 - 2019
XJ Centre Console Lid Button
Old Dec 30, 2017 | 04:14 AM
danbvm's Avatar
Default XJ Centre Console Lid Button
Just upgraded my XF to a 2011 XJ.
I need 2 hands to push the centre console lid button down to open it.
Is this a known problem & is there a fix.
Old Dec 30, 2017 | 05:13 AM
roviw's Avatar
I had the dealer look at mine when it was in for a service, no idea what they did but it was much easier after I got the car back.
I have a feeling someone said the "wax or oil ? " that makes it soft close in the damper was a bit of an issue. There are a few new ones that pop up on ebay from time to time.
Might be worth you asking on the UK jaguar forum as well
Old Dec 30, 2017 | 06:03 AM
dga57's Avatar
The mechanism needs to be cleaned. Do NOT use a spray lubricant or oil because that will only make matters worse. There is an excellent tutorial on how to clean it somewhere in this forum - do a search. Mine was still under warranty when I started having trouble with it so the dealership took care of it for me. Good luck!
Dwayne
Old Dec 30, 2017 | 07:31 AM
XJsss's Avatar
Here are a couple of documents that members put together regarding this problem.
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 30, 2017 | 01:36 PM
Stuart S's Avatar
Mine wouldn't stay closed. Here's my easy DIY fix:
https://www.jaguarforums.com/forum/x...-fixed-177536/
Digital Will
Feb 21, 2026 05:58 PM
oddjob2000
Oct 30, 2016 11:37 AM
booyaford
Oct 24, 2016 11:56 AM
V8FTW
Oct 23, 2016 07:45 PM
Feb 26, 2008 04:06 PM
