XJ ( X351 ) 2009 - 2019
XJL Lowering Solution?
Old Jan 7, 2017 | 01:59 PM
Johncy2000's Avatar
Default XJL Lowering Solution?
Its been years trying to find someone that makes lowering springs for the XJL. Anyone have any leads? Thank you!
Old Aug 17, 2017 | 11:14 AM
Johncy2000's Avatar
Bump!
Old Aug 17, 2017 | 12:34 PM
JagGate's Avatar
Just cut a loop out. Old school!
Old Aug 17, 2017 | 01:39 PM
clubairth1's Avatar
Community Influencer
I have a 2014 XJR and it's plenty low enough! Dang roads are too rough and uneven!
Old Mar 25, 2018 | 03:59 PM
Hank Scorpio's Avatar
kinda back from the dead here....are the Supersports and XJ-Rs not lower than the others? It seems odd that a 3.0 diesel and an XJR would have the same ride height, but stranger things have happened.
If they are in fact lower, we could use the XJR setup in our cars, which i assume is stiffer and lower front springs and a setting for the rear air suspension.
Edit - at least one member had it done custom: https://www.jaguarforums.com/forum/xj-x351-53/modded-xjl-116939/
