XJ XJ12 ( X305 ) 1995 - 1997
A/c compressor
Old Jun 2, 2013 | 07:07 AM
P4nth4's Avatar
Default A/c compressor
hello again all, i need a new a/c compressor because i believe that the one i have now is seized. it wont turn at all. is there any way that i could free it up? also, if i do have to change it out, will the a6 gm compressors work as they are a little cheaper and what year should i get. i have a 1996 xj6, thanks.
Old Jun 2, 2013 | 08:52 AM
Doug's Avatar
If the compressor has seized internally there's nothing to do. It's junk.
An old A6 compressor could probably be fitted with enough money and effort (new brackets etc) but it's an ancient design. It would be lots of work for a step backwards in efficiency.
When you DO replace the compressor make sure the system in flushed. When the old compressor seized it probably sent metal bits throughout the system
Old Jun 9, 2013 | 02:45 PM
basco1987's Avatar
Are you sure it's seized? Check the fuses before replacing (esp. F8 & F10 in the engine bay fuse box RH).
Harald
Old Jun 28, 2013 | 06:41 AM
JTsmks's Avatar
You have a 1996 XJ6? That would be a Denso unit, just bought a Denso (OE supplier) from Rock Auto for $202 for my wifes 97 XJ6L, fit like a glove, works like a champ and about $150 to $250 less then anywhere else.
bdboyle
Sep 16, 2019 05:58 PM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
42Ajd
Sep 26, 2015 07:04 PM
