04 XJ8 101K Miles -- Cooling System Issues -- Heat Gets Cold --
Old Nov 28, 2012 | 05:34 PM
randyshear's Avatar
Originally Posted by evilfij
Not sure if it is the same issue, but my thermostat was stuck open on my car and if stopped, the heat worked ok, but when on the highway at speed (with all the cold air through the radiator) no heat. It eventually set off a CEL. $20 part and should be an easy swap (mine still has warranty). Probably worth a shot.
I think you might have a different issue, namely, a coolant leak. I know you say the res is full, but the pressure loss so quickly after parking is suspect to me. I have been working on cars for eons, but new to jag so I am not sure what the most likely suspects are. If it were a land rover I would know where to look.
I have great heat at all speeds all the time; until the temp guage fluctuates and then things go crazy. Mine is usually opposite from yours, I'll have heat when accellerating, and cold when at a stop. I'm thinking a sticy thermostat in the closed position.. Possibly.. Was hoping for a few more ideas before I start throwing parts at it. The T-Stat is $60 from AutoZone. Thanks!
Old Nov 28, 2012 | 05:36 PM
randyshear's Avatar
Since bleeding it again I've driven her over 200 miles with no issue.. But last time it took almost 1000 miles before she acted up.
Old Nov 29, 2012 | 12:52 AM
evilfij's Avatar
Thermostat is $20 at rock auto.
Old Nov 29, 2012 | 01:27 AM
H20boy's Avatar
Yah steve, I was pretty confident a hard reset would do the same thing, but i've recently learned (through motorcarman and others) that it does not, must have the IDS/SDD to clear the adaptations, and/or update the programming. It seems sometimes that it works, but the hard reset clears the fuel trims and other ECM behaviours, that often messes with shifting...but only for a short time, and long-term adaptations return eventually.
Not just a jag dealer, but anyone with SDD and a real (or cloned mongoose cable) can do the same procedure at home. Cleared my xk8 a few weeks ago when it was in the tranny shop getting some new guts. More and more of us are investing the $200-$500 for the very same tools the dealer has.
Old Nov 29, 2012 | 02:27 AM
steveinfrance's Avatar
Another day, another myth out of the window, well worth knowing.
I'll add it to the 'disconnecting the battery sticky'.
Old Nov 29, 2012 | 09:14 AM
reyesl's Avatar
Question
Request this step be expained in a bit more detail:
Are the cable ends touched together or a cable end to battery post?
Do both cables need to be disconnected or just the ground?
Don't want to damage any components.
Attached Thumbnails 04 XJ8 101K Miles -- Cooling System Issues -- Heat Gets Cold ---tt.jpg
Old Nov 29, 2012 | 10:10 AM
randyshear's Avatar
I really love this forum I'm learning all kinds of great stuff (like how to save $40 on a T-Stat).
Old Nov 29, 2012 | 01:57 PM
  #28
Take the ground (-ve) lead off the battery.
The battery is now only connected via its +ve lead.
Touch the -ve lead to the battery +ve post - you are not shorting anything out.
Old Nov 30, 2012 | 06:58 PM
randyshear's Avatar
Anyone else have any input?
Old Nov 30, 2012 | 10:57 PM
  #30
Randy, I've merged your two threads to keep things together.
Old Dec 2, 2012 | 12:47 AM
  #31
randyshear's Avatar
Thank you.
Old Dec 8, 2012 | 01:52 AM
  #32
randyshear's Avatar
Anyone else???
Old Dec 17, 2012 | 12:03 PM
  #33
randyshear's Avatar
UPDATE:
After flushing the cooling system several times, I haven't had any more issues with the heat going cold on me. I took the XJ8 to a local "garage" and had them do a transmission flush using Castrol Multi Import fluid. At first I had erratic shifts, and harsh shifts.. I was very upset, but I'm happy to say that more than 1,000 miles in 2 days on her she is so much better. The "lurge" from 2-1 is almost completely gone, but still there on occasion. I am at Scholfield Auto Plaza in Wichita, KS and they are reflashing the TCM, and adding any fluids if needed. I'll update more after the car is returned to me. FWIW Scholfield is VERY reasonable on prices ($75 to flash the TCM), loaner cars if needed, huge customer waiting area with free Wi-Fi, free "courtesy work stations", free coffee, soda, etc. Very friendly!!
Old Dec 17, 2012 | 01:57 PM
  #34
randyshear's Avatar
UPDATE 2:
Ok, so they are finished. They gave me a free 140 point inspection, most everything is ok. Needs some minor suspension work (mainly just ripped tie rod end boots, and ripped ball joint boots), tranny pan and connector seal are leaking a little bit. Tranny was 2 1/2 qts low.. (just had it flushed and filled a few days ago, so it appears the shop didn't fill it properly. The tranny leak is small, never any drips on the garage. Just kinda "damp" pan. He had 1 1/2 qts in his cabinet and gave it to me free, only charged me for 1qt. (THANK YOU MASTER TECH!!) TCM reflashed, ECM reflashed, free car wash. This place is absolutely amazing! I'll update after the car relearns everything. The master tech said it'll take about a week to get the ECM and TCM adjusted again. He advised it might be a little querky for a bit lol.
Old Dec 18, 2012 | 10:24 AM
  #35
oldmots's Avatar
This sounds like the thermostat to me. It is probably sticking. Thermostats should be changred at 60K so you are due anyway. There is also an electric pump in the heat system that could be bad. Just check to see if its working.
Old Dec 18, 2012 | 01:41 PM
  #36
N9921x's Avatar
Default Electric aux heat pump
Old mots,
Can you tell me where this pump is located?
How to check its function?
I am already looking for a fuse.
Thanks.
Gary
Old Dec 18, 2012 | 09:13 PM
  #37
randyshear's Avatar
Originally Posted by N9921x
Old mots,
Thanks.
Gary
^^^^ I 2nd that question lol. Where is the pump at? Thanks.
Old Dec 19, 2012 | 10:30 AM
  #38
oldmots's Avatar
It is underneath the coolant header tank where all the coolant hoses come together.
Old Dec 20, 2012 | 10:40 AM
  #39
N9921x's Avatar
Perfectly hidden.
Thank you!
Old Dec 29, 2012 | 01:22 AM
  #40
randyshear's Avatar
Sounds fun to check... At 104K could be going bad.
