08 VP front suspension issues
Old Jul 24, 2016 | 12:52 AM
Fernando's Avatar
Default 08 VP front suspension issues
Hello,
Have an 08 vanden Plastic that needs suspension work. I want to convert to coil over Springs.
I have a couple of questions
1. Has anyone tried using S type struts instead of Arnott or other conversion kits? Read a post about it but haven't seen anything else.
2. Is any way to buy the Arnott conversion coils independently instead of the entire kit. Are they a standard part for another jag or audi etc... money is a bit tight right now. I I would love to convert the front then later switch the backs. Also, is this possible without damaging the car, any other effects besides codes?
I attached a couple of pics of how my car is sitting. Funny enough no codes so far.
Thanks in advance.
Old Jul 24, 2016 | 02:38 PM
Fraser Mitchell's Avatar
So what work is needed on the suspension. If the front is too low and there are no fault codes, a simple re-calibration of the ASM should be enough to sort it out.
Old Jul 24, 2016 | 03:17 PM
Fernando's Avatar
Not that lucky, the passenger front is leaking air.
Old Jul 26, 2016 | 08:09 PM
Fernando's Avatar
Hi,
I finished the front half of the conversion. It was very time consuming but I can't say it was hard. The most difficult part is that the s type shocks are smaller in diameter so you have to make new holes. It would be nice if they were like bmw where the bolts are on a bearing that rotate.
I took it out for a ride, it feels good a little bumpy but I have been told it's normal as the suspension settles in.
I am holding off on the rear. Hopefully I will have it done soon.
Old Jul 26, 2016 | 11:01 PM
Torrid's Avatar
Does the front sit lower than stock height with the coils? That's my only gripe I have about the off the shelf conversion kits. I would have really liked to lower the car in the process.
Old Jul 26, 2016 | 11:07 PM
Fernando's Avatar
1 inch lower
Ducmon
May 12, 2016 07:08 PM
xjtom
Mar 31, 2016 04:16 PM
CHS
Mar 31, 2016 11:23 AM
wyxtype
Mar 30, 2016 05:39 AM
Dec 22, 2005 09:28 PM
