2004 XJ8 air to coil conversion question
Hi Guys
going to be doing the coil conversion with the Arnott kit this coming week,just wondering if there are any bushings or anything else I should be changing while I have things apart,would like to have them on hand so it don't hold up the job
Albert
Albert
I just did mine with some eBay specials - easy job. You really will not be messing with much where there would be a time savings. If you have some suspect parts then do them and save on a single alignment. The hardest part is getting the rear seat cushion out.
You might want to consider the uprated front and rear anti-roll bars if you don't like the increased body roll compared to the air suspension system.
goldgun
Aug 4, 2019 10:53 AM
mbclubph
Jul 26, 2015 10:43 AM
RDMinor
General Tech Help
Feb 14, 2015 08:26 PM
