2004 XJ8 Xenon Leveller Motor?
Old Oct 28, 2013 | 02:13 PM
rhathaway's Avatar
Default 2004 XJ8 Xenon Leveller Motor?
Hi Folks,
I believe my outboard (dipped) headlamp leveller motors are dead. My low beams were quite low, as in straight down, so I adjusted the lamps with the screw, up to where they should be.
Only now, the inboard (high) beams light up the tree tops, leaving a dark void where I'd really like to see ahead of me!
Is there a fuse I can check, and if so, where is it? Do I need to remove the headlamp assemblies to test / replace the motors? It seems that the fascia includes the front bumper cover...
If the motors are unreliable, is there a procedure to adjust the dead motors in a somewhat better position permanently? I'd rather not fork over a grand each for new, unlevelled lamp assemblies.
Thanks in advance for your help!
Rob
Old Oct 28, 2013 | 06:04 PM
Fraser Mitchell's Avatar
Hmm, I wouldn't have thought both would fail together, so it looks as if it's further back than the motors. However, later cars eliminated the electric motors because the air suspension auto-levels the car, so no other adjustment is necessary.
There could be a bad connection. Have you looked at the earths behind each headlamp ?
Old Oct 28, 2013 | 06:39 PM
doc's Avatar
doc
There are 2 adjusters on the headlights one for high beam one for low beam also left and right adjustment
I cant tell you where the high beam ones are it was months ago when I adjusted my lights up
tomsjag
Jun 10, 2023 10:02 AM
afterburner1
Dec 16, 2015 12:12 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
jimbo1948
Sep 7, 2015 03:14 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
