2004 XJR Suspension Question
Old May 21, 2009 | 07:39 AM
les's Avatar
les
It sounds like you have a faulty air shock to me. It isn't uncommon for them to fail so I would get back to the dealer asap.
If it were the compressor by the way, then all 4 corners would be down.
Good luck.
Old May 21, 2009 | 08:43 AM
wazari's Avatar
That's pretty good that you were able to detect only a 1/4" variance. It's possible that your suspension just needs to be adjusted. Ride height can be measured and set for each corner independently by the dealer. That's how you can lower the car too by inputing ride height figures that are higher than the actual number. The car's on board computer will compensate back to the factory settings.
Forcedair1
Sep 8, 2025 01:57 PM
Numwen
Sep 6, 2015 12:30 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
