2005 XJ Super V8 Bolt Pattern & Sepang Wheels
Old Aug 17, 2015 | 08:19 PM
MrWest's Avatar
Default 2005 XJ Super V8 Bolt Pattern & Sepang Wheels
Hello everyone,
I'm looking into getting a set of Sepangs for my newly acquired 2005 Super V8. I'm seeing some conflicting information online as to the specs necessary.
I found a site that has a few slightly different versions listed, which all appear to have the same specs (20x9), but two of them are listed at a 5x4.75 bolt pattern, and one is listed at a 5x4.25 bolt pattern.
I was under the impression that all of these models were 5x4.25, but on the site it says these wheels are compatible with 2004-2006 XJs.
Any ideas?
Old Aug 18, 2015 | 03:23 PM
Muddybear's Avatar
Sepangs could be made XJs and XK's. The difference is that the XK has a staggered setup and XJ has a square setup (All 4 wheels the same size)
The XJs Sepangs are 20x9 49ET @ 5x108mm
Old Aug 18, 2015 | 11:47 PM
MrWest's Avatar
Thanks. I called the place that had them listed at 5x4.75, and their site was just wrong. They were also out of stock, so it was a bust anyway. Gotta keep looking.
Old Aug 19, 2015 | 09:51 AM
Muddybear's Avatar
I have a set of Sepang that I'm not using now, but not really sure about shipping them. If you are around SF you could pick them up. IM me if your interested.
Old Aug 19, 2015 | 01:56 PM
winefan94920's Avatar
Default Muddybear, I am in SF Looking for Sepangs
PM Sent to you.
04Xjrsteve
May 7, 2019 04:06 PM
MrWest
Dec 1, 2015 09:18 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
MrWhite
Oct 1, 2015 01:43 AM
dmatthewman
Sep 30, 2015 10:10 AM
