2005 xj8 heater core looking for cheaper alternative
Old Jul 29, 2021 | 08:15 AM
Aj Leduc's Avatar
Default 2005 xj8 heater core looking for cheaper alternative
Good morning, anyone found a cheaper alternative for the 2005 xj8 heater core.
thank you
Old Jul 29, 2021 | 12:28 PM
xalty's Avatar
a used one
flush it out
Old Jul 29, 2021 | 02:49 PM
paddyx350's Avatar
thank you
This is the one that I bought;
https://www.ebay.com/itm/29324582674...kAAOSweFhe6MhJ
Old Jul 29, 2021 | 07:23 PM
Wingrider's Avatar
Some have had good results, using the C L R product, followed with a back flush.
Being careful not to leave it in too long, as it is corrosive to aluminum.
If your successful in opening things up, be sure to change your coolant, on schedule.
Old Jul 30, 2021 | 05:00 AM
Fraser Mitchell's Avatar
If you follow the flushing route, be aware that it is the surface area available for heat exchange, not the flow through the matrix that counts. Many of these pass the coolant OK, but the cabin remains cool. Flushing on its own is useless, you need something with a dissolving action on the blockage material. I'm not sure what that is, it may be citric acid. The problem with chemical-assisted flushing is that if it doesn't work very well, you've spent a lot of time and effort for nothing, and will have to take it all apart again to fit a new matrix. This is why I bit the bullet and had a new matrix installed.
You can buy aftermarket as said earlier. I also found the same one here: -
Jaguar XJ6 Heater Matrix | X350 X358 Heater Matrix
Tony Dancer
Apr 19, 2021 03:18 PM
Wingrider
Jan 9, 2018 01:10 PM
bniland
35
Oct 15, 2015 07:09 AM
Boilerpete
Feb 16, 2012 08:38 PM
