2007 trunk air reservoir color code?
Old Nov 10, 2020 | 04:22 PM
redxk8's Avatar
Default 2007 trunk air reservoir color code?
Can’t seem to find any reference for the cover code hoses for the reservoir for the air suspension for 2007 XJ8 which is located in the trunk under the spare. Any help is appreciated.
Old Nov 10, 2020 | 08:35 PM
meirion1's Avatar
If you look at the ballast tank and valves in the boot the pipes are colour coded.
Old Nov 11, 2020 | 04:17 AM
Partick the Cat's Avatar
Originally Posted by redxk8
Can’t seem to find any reference for the cover [colour ?] code hoses for the reservoir for the air suspension for 2007 XJ8 which is located in the trunk under the spare. Any help is appreciated.
Air lines colour identification
• Left rear — Blue
• Left front — Brown
• Right rear — Red
• Right front — Yellow
Old Nov 11, 2020 | 08:32 AM
redxk8's Avatar
• Left rear — Blue
• Right rear — Red
ok, thank. Now which relay is #4 to deactivate the compressor. I know it’s in the trunk fuse box, but I cannot find any diagram telling me which is which and what is white.
Old Nov 11, 2020 | 09:25 AM
Renovator's Avatar
White is the air line between the compressor and the valve block.
That's where the make up air enters the system and conversely the path for the air springs to exhaust the system.
gibbon
Dec 30, 2017 08:30 PM
flash88
US Southwest
Jan 27, 2017 04:56 PM
meeburtxk8
Nov 16, 2012 02:29 PM
