2008 xj8
Old Jan 19, 2024 | 08:11 PM
Kbs's Avatar
Kbs
Default 2008 xj8
Catalytic converters were taken off my XJ8 what would cause it to blow blue smoke out the tailpipe
Old Jan 21, 2024 | 11:20 AM
wfooshee's Avatar
Blue smoke is oil burning. The end. Valve seals or rings are shot.
Old Jan 21, 2024 | 02:43 PM
h2o2steam's Avatar
+1 to wfooshee's comment.
From my limited experience, bad rings generally cause oil smoke under load (acceleration), whereas valve stem seals will show up more when engine is working on over-run.
So a quick test is to accelerate hard to see if you are leaving a persistent cloud behind you, then take your foot of the accelerator and let the engine act as a brake for 20 -30 seconds, then just a light touch on the accelerator to see if you then produce a noticeable brief plume.
A brief downhill run is good for an over-run test.
Occasionally on start up I have noticed a big puff of blue (perhaps one start every 30-50 starts) which I think is some condensate it the PCV lines that accumulates and then get drawn into the intake in a burst creating a brief but very noticeable cloud.
Other than that occasional oddity, the car runs clean and is not using much oil.
alex muller
Nov 2, 2023 11:04 AM
