ACC - adaptive cruise
Hi everyone
Hoping someone can help me out.
Had a problem electrical problem with the car, and was messing with SDD. By mistake created a session with no adaptive cruise, and from the menu / add accessories / added a normal cruise, after that my adaptive one stoped working. Created again a session bo chose no cruise in order to be able to remove it from the accessories menu.
Now finally did create a session with adaptive cruise, did try to create a new adaptive module, but will not work.
Now after all it display abs fault, no DSC, and no cruise... I know for sure that the problem is from the ACC, because if fuse 27 is removed, just no cruise is displaying and traction, ABS are fine.
Can someone really have any idea how make the ACC work again ?
oh boy you done ****ed up. go into appdata or wherever the VID gets saved and reupload the oldest session you can find back into the ecm.
if you didn’t the as built should have ACC in it. look up 32-bit recovery procedure basically unhook the ecm and force a no-comm until it decides to use the as-built
