Air compressor mounting help after removal
Old Nov 6, 2022 | 03:39 PM
JagsteRJX's Avatar
Default Air compressor mounting help after removal
Hi All,
I had a mechanic replace the air compressor piston ring, and not long after the compressor started constantly coming on, it also developed a loud vibration when running.
I managed to get the car up on a hoist and found one of the mounting nuts was loose. I tightened it up and the vibration went away. However, after removing the compressor today myself to take a look at why it is constantly coming on, I noticed things don't seem correct with the mounting system and I'm unsure how to assemble it again. It appears mounting parts are missing from previous jobs. I only have 5 metal bushes, 2 springs and 1 rubber bush. The workshop manual shows there should be 6 metal bushes, 3 springs and 3 rubber bushes.
I don't want to install it just to find it starts vibrating again, I would rather do the job properly the first time. Any help would be much appreciated.
Thanks.
Old Nov 7, 2022 | 02:41 AM
flatsix's Avatar
It is what it looks like, one (half) metal bushing, two rubber bushings and one spring are missing.
Fritz
Old Nov 7, 2022 | 01:22 PM
JagsteRJX's Avatar
A quick update. I've had to install the existing parts back as they were previously, after installing a new piston ring. After getting the compressor installed and the nuts back on, I went to torq the nuts down to 15ft-lb and one of the threaded studs on the mounting bracket snapped , so now I need a new bracket, as the compressor is vibrating like mad. I could probably cut the stud and add washers to reduce the vibration, but I still wouldn't have the rubber bush or one of the metal bush on that stud, as it is shortened too much. I'll have to redo the entire job now, what a PITA!!
On the bright side, the air suspension fault light on the dash has decided to disappear . One step forward, 2 steps back.
theeogflip
Jan 14, 2022 08:31 AM
retroren
Jun 27, 2021 09:26 AM
Aarcuda
Aug 5, 2020 11:13 AM
Howie1971
Dec 2, 2018 02:40 AM
fingers
Aug 14, 2016 11:35 PM
