Air Suspension Help!
Old Jan 7, 2014 | 10:56 PM
nickmackie1990's Avatar
Default Air Suspension Help!
I work at a Cadillac dealership and im working on a 2004 XJ8. I brought the vehicle into the shop the other day and the suspension height was normal. Today after I had finished all the services on the vehicle, I noticed the front suspension sagging and touching the inner fender wells. After starting the vehicle, i let it sit in the shop for about 20 mins to see if the bags would air up but after running the bags would not air up and the compressor would not engage. I have already inspected the air bags and the air lines for leaks and the air bags/lines are ok. I have also already checked the compressor fuse and the relay and found both were ok. I did however found that there was no power going to the compressor, but i do know the wiring is ok going from the fuse block to the compressor. If anybody and help me out it would be greatly appreciated!!
Old Jan 8, 2014 | 04:30 PM
anindyam's Avatar
Sounds like the compressor is bad or struggling with the cold weather. Mine is giving me issues down here in Austin, where, I'm sure, it isn't as cold as it is up where you are.
Does the "Air Suspension Fault" or "Vehicle Too Low" message appear on the dash?
Old Jan 8, 2014 | 05:47 PM
meirion1's Avatar
try driving it around the block for up to 20 mins.
Old Jan 9, 2014 | 04:00 PM
reyesl's Avatar
Are the electrical connections to the air-valve block OK?
File Type: doc
File Type: doc
Old Jan 9, 2014 | 04:37 PM
Fraser Mitchell's Avatar
Are there any fault codes, and have you read them ?
I see you're in Michigan and the weather has been ever so slightly cold there. Was the car in a warm shop ? If the car is low, and the compressor isn't coming on to charge the reservoir, I'd suspect the front height sensor.
philwarner
25
Jun 26, 2021 05:43 AM
Forcedair1
Feb 19, 2020 01:51 PM
scooternva
19
Oct 27, 2015 02:14 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
