Alternator?
Old Oct 16, 2019 | 02:40 PM
Peterinio's Avatar
Default Alternator?
My '09 VDP has had an engine whirring sound for a while now. I changed the belt tensioners, but still whines. Could it be the alternator? I checked the battery under load and it reads around 14.
Could use a hand on this.
Thanks.
Peter
Old Oct 16, 2019 | 02:45 PM
Wingrider's Avatar
Check the idler pulley bearing.
Old Oct 16, 2019 | 02:53 PM
jackra_1's Avatar
+1 on that.
Easier than it sounds tho.
I ended up replacing all my pulleys except the super charger pulley.
Also replaced the alternator due to a separate issue and went thru several so called "compatible" alternators before I got one that worked without the alternator light coming on.
A local shop, 50 miles away, could not repair my alternator or rather refused to after they said they could no the phone.
Old Oct 16, 2019 | 03:04 PM
Wingrider's Avatar
Brushes are mostly what wear out on these alternators, change them at 100,000 miles or so.
Used ones from wrecked cars are cheap.
Old Oct 16, 2019 | 03:05 PM
Peterinio's Avatar
Yes, I replaced that with the belt tensioner.
Old Oct 16, 2019 | 03:16 PM
Peterinio's Avatar
I just looked briefly online and couldn't locate brushes. I'll look further.
What about the whirring sound? Would this be the alternator bearing? (pulley)
Old Oct 17, 2019 | 06:36 AM
Wingrider's Avatar
Home > JAGUAR > JAGUAR ALTERNATOR > Alternator for 4.2L Jaguar 2003-2008 S-Type, 2004-2009 Vanden Plas, XJ8, XJR, XKR, 2003-2006 XK8 (104210-3080, -3081, -3082, -5040) - 13979 > Alternator Repair Kit for 4.2L Jaguar 2003-2008 S-Type, 2004-2009 Vanden Plas, XJ8, XJR, XKR, 2003-2006 XK8 (104210-3080, -3081, -3082, -5040) Regulator Brushes Bearings - 13979RK
4.2L Jaguar Alternator Kit
Item #:13979RK
Your Price:$39.99
Home > JAGUAR > JAGUAR ALTERNATOR > Alternator for 4.2L Jaguar 2003-2008 S-Type, 2004-2009 Vanden Plas, XJ8, XJR, XKR, 2003-2006 XK8 (104210-3080, -3081, -3082, -5040) - 13979 > Alternator Rectifier Diode Assembly M8-1.25 with 12 50 Amp Diodes replacing Denso 021580-6110 - 77904042
Rectifier Replacing
Denso 021580-6110
Item #:77904042
Your Price:$29.99
Quantity:
Maniac Electric Motors, is the name of the place, these parts will fix your alternator.
Their in my 04 XJ8's rebuilt alternator right now
Old Oct 17, 2019 | 09:38 AM
Peterinio's Avatar
Wow! That is supremely helpful. Thanks Wingrider. If that is your real name...
rbarreto
Sep 23, 2019 06:41 PM
Brewtech
Apr 11, 2018 12:15 AM
dwgates
Feb 16, 2018 10:35 AM
Alster370
May 29, 2017 11:30 AM
usmc1211
Mar 24, 2014 05:19 PM
