another wiper refill question
Old Feb 26, 2013 | 07:53 AM
mhamilton's Avatar
Default another wiper refill question
I searched and read many threads on the wiper blade replacement. Apparently I didn't read well enough, because I bought Bosch Icons. I got them to fit (sort of)... but the J hook binds up and the blades don't contact the window evenly. Guess those are going back.
I read that the Trico blades work correctly with the washer jet pieces? My question, do those also allow the aerodynamic wing to attach? Or should I just give up and buy a refill for the original blades?
Thanks,
-Michael
Old Feb 26, 2013 | 09:33 AM
SuperTrav's Avatar
I used Trico refills. They in no way inhibit or obstruct any OEM elements of the wiper assy's. It was simply "Remove and Replace". And they work perfectly.
Old Feb 26, 2013 | 04:06 PM
meirion1's Avatar
You could try taking a bit off each side of the J hook by rubbing them on emery paper which is flat on the bench, if you see what I mean.
Old Feb 28, 2013 | 06:47 AM
mhamilton's Avatar
Thank you for the replies. I ended up finding the Anco N24-R, N19-R refills at AutoZone. They do fit and work fine so far, but I'm not very happy about the low quality of the blade material. But I guess for $7 I can use them up and then go buy OE refills from the dealer.
johndahlheimer
Sep 17, 2020 03:10 PM
HypnoGuru
Oct 23, 2018 09:53 AM
CaneCounsel007
Nov 13, 2015 09:05 PM
chatmanx
Sep 11, 2015 07:17 PM
XJsc-guy
Sep 2, 2015 11:43 AM
