Another XJR belt squeak post
Old May 13, 2025 | 08:53 AM
arctic_man's Avatar
Default Another XJR belt squeak post
After some deep diving into the search engines, I have come up somewhat empty. I have some belt squealing going on and really want to get it right the first time and not have the car torn apart for a week waiting for parts and such.
My intention is to replace all the bearings themselves, as I do not want to perform the double groove belt upgrade, and don't want to spend extra dollars on replacing all the pulleys when I have the tools to just swap the bearings themselves.
That being said, does anyone have a list of bearing numbers for the idlers and tensioners? Or can confirm that these bearings will fit? I saw this post referenced on the 308 page a few times, but I could not find out if they actually did fit.
https://www.jaguarforums.com/forum/x...acement-65171/
Old May 17, 2025 | 08:25 PM
arctic_man's Avatar
Solved my own problem. In case anyone else looks. Yes, they are the same. If you are doing idlers and tensioners you need:
1xSKF 6303-2RSH/C3 and 3xFAG 6203.2RSR
I would also recommend doing the belt too. I am waiting on parts, but spent a tad cross-referencing part numbers to make sure.
I would buy on Ebay or local to make sure you get genuine parts. Or somewhere other than Amazon.
LI04XJR
Mar 13, 2024 07:53 AM
Marco_2001_XJR
May 23, 2017 07:05 PM
Dickie_L_J_O
May 1, 2015 11:02 AM
newuser
May 5, 2012 08:10 AM
Sparkers69
Oct 21, 2010 12:09 PM
