Apply foot and park brake/check pressure spare tire
Old Jan 2, 2022 | 01:41 PM
Donhicks1's Avatar
Default Apply foot and park brake/check pressure spare tire
Hello guys. I recently change passenger air strut. Had problem inflating but i loosen front line to left front shock drain down and cranked again an it lifted car even. But now i have another problem in dash reads apply foot and park brakes/ check pressure spare tire. I never replace tire with spare. I read about inflate tire higer than requied. And help wood be appreciated. I have a 2007 jaguar XJ8L 100.000 miles on it beautiful car
Old Jan 2, 2022 | 05:28 PM
Wingrider's Avatar
Could be battery in the sensor going out, they are 14+ rears old
Old Jan 3, 2022 | 04:12 AM
Petz's Avatar
I suppose you unplugged batterie before airstrut exchange
so it would be normal to have to push footbrake and the apply handbrake holding a couple of seconds.
As well roll dow window , roll up and holding the actuator a 6 seconds when closed and to do that on every window .
then your radio code will be asked as well
Old Jan 3, 2022 | 04:21 AM
Petz's Avatar
I guess yours has tire inflation sensors . Cant help you with that.
-4,2 bar is generally used on emergency narrow spare tire/.4,2 when in use
-3,0 for normal spare tire and /around 2,3 when in use
Panelhead
Jun 18, 2021 07:37 AM
NavyBlue
Sep 11, 2019 03:23 PM
r0m8470
Aug 28, 2013 10:45 AM
Long Islander
Jun 13, 2011 03:44 AM
