Ball Joint Splitter/Separator Tool
Old Jul 20, 2025 | 07:11 PM
87LC2's Avatar
Default Ball Joint Splitter/Separator Tool
Replacing the front lower control arms and unfortunately the ball joint splitter I have will not open wide enough to work on the Jag. I know the OE tool (PN 204-327) is wider, but they don't seem to be available. Has anyone had any luck recently with a tool on the market that is still available?
This is similar to what I have, just not big enough - https://www.minimania.com/part/07-03...Splitter-Lever
Old Jul 20, 2025 | 09:23 PM
xalty's Avatar
amazon
Old Jul 21, 2025 | 07:31 AM
87LC2's Avatar
Originally Posted by xalty
amazon
The one I have is from Amazon, only opens to about 2 1/8", need just a bit more and I don't see any on there that open wider. Happen to have a link for one that works on these?
Old Jul 21, 2025 | 04:51 PM
Wingrider's Avatar
Old Jul 21, 2025 | 05:51 PM
meirion1's Avatar
I have just done this job on both sides
You will need to remove the caliper and brake disc then
take the hub and straight control arm to Pedders to seperate
them
They did them FOC both sides
Mech said the joints were very tight
Old Jul 22, 2025 | 08:34 AM
Wingrider's Avatar
Did mine with a BIG set from the auto parts store.
The larger set, required a deposit of over $200.
This set has a ball joint reciever cup.
That is large enough to accomidate removal of the joint.
Believe that size cup is also available at Harbor with the add on kit
Used the 1/2" impact gun to remove & install, on both cars
Old Jul 22, 2025 | 09:15 AM
87LC2's Avatar
Thanks guys, ended up borrowing one from a coworker and got it to work. It was the same style as the one I had, but with just about 1/4" more on the opening, that was all I needed. Glad I was able to separate the joint from the arm without damaging it, joint is in good shape and no need to replace it at this point.
David Dougherty
Dec 14, 2024 04:52 AM
Stamford
Dec 13, 2022 04:03 PM
13was13
May 16, 2015 07:44 AM
04xtype04
Apr 7, 2014 07:07 PM
elmostro
Aug 16, 2009 11:36 AM
