Bleed Nipple Thread Size
For a 10mm spanner size .............. M10 X 1.0
For a 8mm spanner size ................M6 X 1.0
If the bleeder is seized it will most likely tear the thread out or snap the bleeder ,
in that case you will need a " Bleeder Repair Kit " , you don't need to replace the caliper .
Good luck with that
Good luck with that
