Bluetooth module
I have a 2005 xj8 x350 4.2 supercharged and I am trying to locate the Bluetooth module unit, have tried the boot there is a 6 cd multi changer and a dvd player, have looked under spare wheel any help please.
Welcome to the forum tonto7,
I've moved your question from General Tech Help to X350 forum. This is the place to post technical questions about your model. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
IF you have one it will be in the rack that houses the DVD player and multi disc unit.
You have to take the trim off to see. |
Thanks Jackra 1. There is only the dvd and cd multichanger, would the wires and connector be there so if i buy a second hand unit it would just mean plugging it in do you know.?.
Originally Posted by tonto7
(Post 1808404)
D2B optic cable is available on Ebay and can be used to add in another module, such as a bluetooth module, into the existing closed loop. If they are present you would also need a microphone and an aerial. I bought my bluetooth unit on Ebay along with an OEM microphone that I installed in the roof console along with a BMW aerial. Have a look at https://www.jaguarforums.com/forum/x...e-info-177635/ |
