Broken hood cable
Old Oct 19, 2025 | 11:27 AM
Panelhead's Avatar
Default Broken hood cable
I have decided to part out or dump my 2006 XJR. I let sit in driveway for over a month and battery is dead. Hopped in to hook up to fuse box to unlatch trunk. Pulled hood release lever and it popped.
Let sit but got out this morning. It was intact under dash. Broke under hood at mechanism.
Is there a non destructive way to release hood?
Old Oct 20, 2025 | 04:30 AM
Petz's Avatar
If you have the xjr grill you do have the possibilety to go from below . Remove first tray behind bumper and try to reach up .
if you have the SE grill you can pull those out by using a piece of cloth showe in at the top and out at bottom one slight pull no damage
Old Oct 20, 2025 | 04:34 AM
Petz's Avatar
Depending on the condition of cable attached to the pull handle inside cabin ... might have to take trim out and grab cable with a plier and pull
nobody1942
Jul 21, 2024 01:05 PM
JWheaton10
May 17, 2017 02:53 PM
bobsalmon
Dec 20, 2016 04:57 AM
quinnjere
Sep 2, 2014 10:08 PM
pab
Jun 21, 2011 09:28 AM
