Car left sitting over winter
Ladies and Gentlemen,
I really screwed up and left my 2007 Jaguar XJR out this winter and when I went to try to start it, the battery was DEAD. Like flatline dead. I read these forums and did not try to jump it. I instead bought a battery tender with a REPAIR module in it. I put the REPAIR module on for 18hrs., and got the battery up from 8 Volts to 13.7 Volts. I jumped in and got the car to start but it went into limp mode. After making some calls, a tech suggested I disconnect the terminals from the battery completely and let sit disconnected for 2 minutes and then put the terminals back on the battery. I did that and VOILA! the Jag started and ran like a top! I took it for a drive and it ran AWESOME! So note for the future........if you get low battery voltage, use a battery tender, get the voltage up. Start the car and see what happens. IF it goes into limp mode, disconnect the terminals from the battery, let sit for 2 minutes, reconnect terminals and it should reset the ECM, and the car should run great! Hope maybe this helps someone.
Cheers,
Eric Schutte
Cheers,
Eric Schutte
