Check engine light / P0442 fault code on 2005 XJR, charcoal canister issue?
Old Oct 29, 2020 | 12:35 AM
garethashenden's Avatar
Its the same Evap leak code its always been. Once the check engine light comes on it stays on until it gets reset.
Old Mar 5, 2023 | 03:43 AM
Petz's Avatar
Went through sll of this
cancelled my codes with Sdd they only reapeared after driving for about 100km
Erased again we did a reflash lets see
hope to pass technical control in my country
But looking to solve the problem
2003 xj8 4,2 x350 220tmiles/ 353t km
Old May 25, 2023 | 01:26 AM
Petz's Avatar
Well the orange engine light came up again after about 400km but the technical control /Mot I passed.
so go to go. Never the less am I trying to find the problem.
I 'LL REPORT BACK
Old Nov 11, 2025 | 04:04 PM
Droneman's Avatar
Default Evap code 442 and 456
I 'LL REPORT BACK
2004 xjr , I’ve finally finished the coil over install and some control arms and front hubs and now I have these codes. The gas cap is tight but it doesn’t click , it just tightens and that’s it. Put Vaseline on filler pipe under cap but that didn’t help. I get the codes after revving up to 3500 for 5 seconds and driving at 60 mph for 10 minutes. I’m going to look at the small canister, hope I can find it.
Old Jan 1, 2026 | 03:10 PM
Droneman's Avatar
Default Purge
I tested the purge valve under the left front fender and it checked out, opens and closes , can hear it clicking. I’m still getting the 442 and 456 codes, I’m at a loss, going to bring it to a mechanic. There’s also no sound from the radio and a small coolant leak, too cold out now to work on it. But it drives incredibly!
BDuncan
Sep 4, 2021 07:52 AM
pricey x7
Feb 6, 2020 06:42 PM
jpmc86
Sep 29, 2017 03:28 AM
Terry Keeling
Jun 30, 2017 10:48 AM
jagman96
Aug 11, 2010 10:35 PM
