climate control not working
Old Jul 16, 2016 | 06:14 AM
matteblackcat's Avatar
Default climate control not working
I have an XJ8 2003 my climate control does not seem too work anymore , when you adjust fan speed there is no fan noise or cool air coming thru the vents,
have checked fuses and they seem ok
is there something simple i could do before I have to book it in ?
Old Jul 16, 2016 | 06:32 PM
meirion1's Avatar
This is a common fault on this Jag.
It usually is a failed transistor and /or thermal fuse in the blower speed controller.
This is located on top of the ducting behind the glove box and therefore you need to
lower the glovebox to access.
There will be lots of info on this if you search this site.
Old Jul 24, 2016 | 02:14 PM
Fraser Mitchell's Avatar
Yes, a common problem on the earlier cars, (it happened to my car). The later modules had longer cooling fins that cured the overheating that then caused the electronics to fail.
Old Jul 29, 2016 | 02:45 AM
thanks for your advice guys, I rang jag Australia and they said that i had to buy the whole blower unit @ $1200 (aud) but with a little search on the web,i ordered just the module from america for $200 , fitted it in about an hr and is now working perfectly
thank you very much for the advice
Old Aug 2, 2016 | 12:57 AM
suiteddeuces's Avatar
Yep I had the same issue recently as well and also posted. Supposedly my XJR isn't a fan of 115 degree days. Just to mess with me, the air decided to turn on for 10 minutes today just to rub it in. After doing much resear h on these forums, I'm not even gonna bother having a mechanic look at it. I ended up purchasing the c2c39577 part on eBay and will just get it installed by a trustworthy mechanic.
Old Aug 2, 2016 | 04:34 PM
Of course it begs the question as to why some idiot at Jaguar Australia said the whole fan unit had to be purchased, when the fan control module has a Jaguar part number !
Old Aug 3, 2016 | 01:12 AM
meirion1's Avatar
Perhaps he wasn't an idiot -just a crook.
v10killer
General Tech Help
Jun 8, 2016 09:49 AM
cooldood
19
May 9, 2016 09:15 PM
v10killer
Apr 29, 2016 07:10 PM
springer
Apr 22, 2016 11:05 AM
kingcobra
Apr 19, 2016 02:22 AM
