Coolant Leak From Rear of Engine While Off
Old Aug 28, 2025 | 07:18 PM
mmoreno's Avatar
Default Coolant Leak From Rear of Engine While Off
Hi everyone,
I have a 2005 XJ8L (128k miles) and it has a leak of coolant somewhere on the rear upper passanger side (US) of the engine. What's interesting to me is that it leaks almost all the coolant while the engine is off. Needless to say, the "Low on coolant" warning shows up, so it is pretty much grounded until I get hat fixed. Its hard to see what it could be back, but it seems to be coming from a threated cover of a hose or something with a lot of play to it. I tried looking up diagrams online to see if I could match the location of it on my car, to no avail. Any idea what it could be?
Thanks in advance
Old Aug 29, 2025 | 08:04 AM
wfooshee's Avatar
Very very likely the hose under the intake manifold. I goes from the throttle body to a point on the front of the Vee. If broken, it will fill the Vee with water, which runs off the back of the engine. You must remove the intake manifold to replace it, which is its own chore.
Here's the hose:
The hose has a reducing adapter in it which is plastic, which is where mine failed, although the large-diameter section was ballooned quite badly and was not long for this world itself.
The replacement hose most widely available is a one-piece molding:
Here is the fitting at the front of the engine, looking forward:
I went through this in my cooling system overhaul, a thread linked in my signature, and you can look there for details about the manifold and getting it off.
Old Aug 29, 2025 | 08:59 AM
mmoreno's Avatar
Here's the hose:
That could very well, be it. We replaced the thermostat housing which had a crack on it and it fixed a leaks we saw. I guess we will go deeper. I'll keep this updated.
Thanks a lot!
Old Sep 1, 2025 | 07:52 AM
Thomas-S.'s Avatar
The hoese is commonly called the "valley hose", so if you search the forum for thise words, you should be able to find lots of threads on the topic.
Best regards,
Thomas
Old Sep 2, 2025 | 08:55 AM
mmoreno's Avatar
What is the part number or a website I could order the hose from? I don't think I'm sure which one to go with.
Old Sep 22, 2025 | 06:12 PM
mmoreno's Avatar
Quick update on the leak:
Fixed.
Got the suggested hose that is one whole piece and found that fixing that exposed a radiator crack the previous owners tried patching up with BJ weld and tape(?). We replaced the radiator and it cools like a charms.
Thanks everyone!
Hose that broke
Hose that broke
phoretwan
Aug 3, 2025 11:42 AM
Car Crazy
Oct 30, 2023 10:59 AM
jrb53
Feb 19, 2015 09:51 AM
stephen11962
Dec 6, 2010 07:38 AM
sempire
Nov 18, 2010 09:20 AM
