Differential fluid
Old Mar 20, 2018 | 02:24 AM
Nalahung's Avatar
Default Differential fluid
Hi all,
I am planning to change the differential fluid on my 06 XJ8 L 4.2. Not sure if anyone can help to provide the spec of the differential I should use?
Thanks.
Old Mar 20, 2018 | 06:40 AM
Partick the Cat's Avatar
The Jag/Ford spec is M2C-192A Synthetic which is 75w140 synthetic hypoid gear oil
Old Mar 21, 2018 | 01:00 AM
Nalahung's Avatar
Thank you!
Old Mar 23, 2018 | 09:35 PM
kbeachy's Avatar
On my first 04 VDP, I successfully used AMSOIL Severe Gear SAE 75W-140.
I also like Lucas products a lot, and with my second 04 VDP I just bought a quart of the same grade Lucas gear oil to use.
Old Mar 24, 2018 | 12:57 PM
Box's Avatar
Box
Valvoline SynPower full synthetic 70W-140 is available at most parts supply stores.
bfsgross
Aug 25, 2014 10:49 AM
2000SType40
Nov 6, 2010 11:20 PM
princemarko
Sep 22, 2010 10:46 AM
umpire554
Sep 14, 2010 10:36 PM
2000SType40
Jan 8, 2009 09:22 PM
