Engine temp
Old May 30, 2017 | 05:50 PM
kbeachy's Avatar
Default Engine temp
Before I purchased, a previous owner switched the engine coolant to the green and away from the pink (dex-cool). My engine temp runs 194-197 degrees max now. What should it run at, and does the dex-cool make it run cooler? Thanks.
Old May 30, 2017 | 05:55 PM
Sean W's Avatar
kbeachy I have the same Engine/Trans as you in my 07 XK and run dexcool. My max temp has been 197.4 degrees and typically run the same as you.
Old May 30, 2017 | 06:31 PM
NEO Cat's Avatar
On my 04 XJ8 the temp averages 195. Will creep up to 198 on a hot day or stopped in traffic with dexcool in the system.
Old May 30, 2017 | 07:55 PM
kbeachy's Avatar
What is it about dex-cool, then, that makes it advisable for our Jags?
Old May 30, 2017 | 10:05 PM
Mikey's Avatar
Improved compatibility with the materials used in modern engines, extended coolant change intervals.
Old Jun 25, 2017 | 03:30 PM
XJPurr's Avatar
My code reader shows 190-198 usually, with 209 max. Started monitoring the temp after electric cooling fans began running for a few minutes after the engine was switched off. The coolant reservoir tank has a small leak and I suspect that is why the electric fans are running, and maybe why the temp spiked to 209 degrees.
Old Jun 26, 2017 | 06:34 AM
jackra_1's Avatar
Dont forget you cannot/should not mix the two! You will get a gel formation that will block the cabin heater matrix at the very least.
