Fast help please: Air Suspension and Jacking
Old May 27, 2015 | 04:03 PM
paydase's Avatar
Tank you very much Sean, this is a very useful tip!
I will look for such a cross beam
Old Mar 7, 2016 | 01:32 AM
AngelM's Avatar
hello everyone,
i replaced my right front air strut and height sensor on my 2004 van den plas, since then the right front has been has been under inflated and the vehicle not leveled. i have tried three of the four various jaguar dealers in the area in the past for various work and they have never solved my issues. i took my jag to one jaguar dealer immediately after i installed the two parts and the dealer said that i had to replace the right front strut before they could do anything to the suspension. i have tried many posts on how to level my front struts but had no luck. i am very mechanically knowledgeable as i work on all my cars but this cat is very stubborn. any input would be very appreciated!!!
Old Mar 7, 2016 | 03:35 AM
clifton94's Avatar
Hi you may need to have it recalibrated
Old Mar 7, 2016 | 04:23 AM
Fraser Mitchell's Avatar
Hi AngelIM
What did you replace the strut with, i.e. was it a new OEM or aftermarket ?
Old Mar 7, 2016 | 06:04 AM
Partick the Cat's Avatar
If you replaced the height sensor then you need to recalibrate the suspension height. You need a special lead and computer program to do this. The official lead is very expensive but Chinese clones available in the internet.
'Google' Jaguar and Mongoose (sometimes called Mangoose to avoid copyright issues ?).
Try searching here for similar threads with 'Mongoose', 'SDD', 'suspension height' sort of thing.
Alternatively, cannot you find an independent Jaguar garage ? They are generally all round better than official Jag agents.
Old Mar 7, 2016 | 06:44 AM
Bagpipingandy's Avatar
yes if you have replaced the level sensor it will be fitted at slightly a different attitude and will need calibrating to perfectly level the car
regards
Andy
Old Mar 7, 2016 | 06:42 PM
AngelM's Avatar
it looks that way only the dealerships in my area may not want to work on an older car
Old Mar 7, 2016 | 06:44 PM
  #28
AngelM's Avatar
i replaced it with an arnott strut and a used height sensor
Old Mar 7, 2016 | 07:07 PM
AngelM's Avatar
thanks Patrick. i may try a fourth dealership and see if they can help
Mugatu
22
Jun 23, 2020 01:50 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1964Daimler
Sep 9, 2015 11:28 AM
02jagstype
Sep 4, 2015 08:20 PM
philwarner
Sep 3, 2015 10:14 PM
