Fluids Needed
Old Jan 8, 2024 | 11:23 AM
ulshaferkl's Avatar
Default Fluids Needed
I have purchased a used 2005 Vanden Plas and am researching the fluid types and quantities to use. Is the below information correct?
2005 Jaguar Vanden Plas with 4.2L V8 - Naturally Aspirated
  • Engine Oil for X350 4.2L Naturally Aspirated Engine: 5x30 Mobile 1 European Car Formula 6.3 qt
  • Transmission Fluid for ZF 6HP26 : Lifeguard 6 , (Ford Motorcraft Mercon SP and Shell Spirax S4 ATF MSP are identical to Lifeguard 6). For drain and fill, you need 5.5 liters / 5.8 quarts. For complete flush, you need 9.5 liters / 10 quarts.
  • Brake Fluid: Shell DOT4 ESL or a low viscosity DOT4 brake fluid that meets ISO 4925 class 6 requirements.
  • Power Steering Fluid: DEXRON III.
  • Antifreeze: DexCool
Old Jan 9, 2024 | 09:40 AM
DaveAllen's Avatar
From my notes for my 2007 Jaguar XJ8
Engine: 4.2 Liter V8 Quad Cam AJ34
Gearbox: ZF6HP26
Final Drive: Gen 2 - not LSD
Here's what I use (capacities are approximate):
Coolant
OEM Spec: WSS M97B44 Extended Life Coolant. (ORANGE)
Used: Peak OET European Coolant (PINK) after thorough flush
Capacity: 14 US Quarts
Engine Oil
OEM Spec: Castrol 5W-30 to Jaguar specification WSS M2C913 - A or B.
Oil specification -API SL/EC and ILSAC GF-3
Used: Mobil 1 5W/30 Synthetic or Castrol Edge
Capacity: 7.4 qts including filter
Power steering:
OEM Spec: Dexron III
Used: Mobil 1 Synthetic ATF
Transmission Fluid
OEM Spec: ZF
Used: ZF Kit
Final drive:
OEM Spec: 75W-140 M2C192A
Used: Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Capacity: 1.25 US Quarts
Brake Fluids:
OEM Spec: DOT 4 ISO 4925 Class 6
Used: Bosch ESI6
Capacity: 1.5 US Quarts for full flush
HTH, Dave
Old Jan 11, 2024 | 12:36 PM
ulshaferkl's Avatar
Gearbox: ZF6HP26
Coolant
Engine Oil
Power steering:
Transmission Fluid
OEM Spec: ZF
Used: ZF Kit
Final drive:
Brake Fluids:
Used: Bosch ESI6
HTH, Dave
Thanks Dave for the response. This is great information to a novice Jaguar owner.
Golfbalz
XJ40 ( XJ81 )
Oct 14, 2022 08:41 PM
Golfbalz
Oct 14, 2022 06:07 PM
Golfbalz
Oct 14, 2022 03:39 PM
rendo
Dec 23, 2014 10:44 AM
kchirume
Aug 10, 2013 01:22 PM
