front reflector
Old May 21, 2022 | 01:52 AM
tommyknocker's Avatar
Default front reflector
Hi all. Does anyone know how to replace the reflector in the front bumper of the X350?
I've busted mine and have bought a replacement. It looks like its just a clip on affair but does the wheel and inner liner have to come out in order to access the rear of the bumper or is there a quicker way that I'm not aware of.
Thanks in advance.
Mark.
Old May 24, 2022 | 12:46 AM
FreeWifi's Avatar
It's just held in by two metal clips on each top end and a plastic tab toward the front of the car. You will need to use a plastic trim tool or similar so you don't scratch the paint and pry from the top. it will pop out from the top and you just swing the unit down to the ground (like your opening an oven door). When I took mine out to replace the bulb socket (vw socket is a good replacement for the rusty bulb socket) it was in there pretty tight. So tight you think you're doing something wrong but you're not.
Old May 31, 2022 | 01:10 AM
Thanks Freewifi, yes just as you said and just as easy. thanks again
Pantherman2
Jul 6, 2016 03:32 PM
diamond_tom
Feb 6, 2014 01:57 PM
AlbBolivar
XJ40 ( XJ81 )
Jun 21, 2013 06:02 PM
raschwar
Apr 25, 2013 05:19 PM
raugajrjx
Jan 22, 2012 04:57 AM
