Fuel gauge off the clock
Old Feb 25, 2012 | 07:54 AM
teejay246's Avatar
Smile Fuel gauge off the clock
This one's a LULU! I have an ECT ( engine coolant temp sensor ) issue and have had to run with codes showing rich for a 100 miles or so. New part arrived yesterday, not fitted yet. Had to do a short run to shops. Fuel gauge "off the dial" pointing towards "temp". When ignition off gauge only drops to 3/4. Switched on an off again - no change. Seems like needle had a power surge or something??? Also engine was over revving for most of the journey, ticking over warm at 12-1500 revs. Bad starting from cold but has been OK when warm. About to put in new ECT sensor today but very concerned about the fuel gauge issue - it's a real weirdo!
Old Feb 25, 2012 | 12:37 PM
teejay246's Avatar
Smile fixed
Well, Well! No doubt the answer is on it's way from someone but I resolved it. Disconnected the battery for 2 hours, then saw gauge drop to read 1/2 ( it was 3/4) before when it should have been at zero ( ignition off ). When I reconnected battery the gauge returned to zero. All OK. Oh and I changed over the ECT and the engine started and stalled. So replaced the MAF all OK Deleted the old codes, went for a run ( what a difference ). Got back still no codes. I will know tomorrow on a 100 mile round trip whether its a proper fix. Watch this space.
Old Feb 26, 2012 | 03:32 AM
Cadillac's Avatar
Cool, good for you and thanks for your feedback
99xk8guy
May 28, 2024 09:36 PM
ccfulton
Sep 20, 2015 05:15 PM
adamn
Sep 10, 2015 09:23 AM
1964Daimler
Sep 9, 2015 11:28 AM
AL NZ
Sep 4, 2015 08:39 PM
