Gentlemen Check Your Speakers!
Old Apr 17, 2017 | 09:21 AM
viper1996's Avatar
Default Gentlemen Check Your Speakers!
I thought my audio system did not sound quite right...I had 1 dash speaker that was going...Well I replaced it and it made only a slight difference...Hmmm I said and began to poke around...As it turned out my left front, right front, and right rear bottom door speakers were all dead...After a little research here, I found that the voice coil lead connections are a common problem on the Alpine speakers...After removing the door panels which was pretty easy, I removed them and soldered a jumper wire to the two voice coils and one at a time they all came back to life...What a difference in the sound quality! Take a listen and post your results!
Old Apr 19, 2017 | 03:06 PM
XJ8JR's Avatar
My system sounds as good as ever, but I'll definitely keep this in mind for future reference.
Old Apr 19, 2017 | 05:56 PM
hisport's Avatar
Thanks, Viper
What year and model is your XJ?
Are these the leads which attach to the speaker cone?
Old Apr 20, 2017 | 10:06 AM
viper1996's Avatar
04 XJR...Yes..I soldered jumpers from the cone or voice coil wire to the original spot they were soldered to on the speaker housing
Old Apr 20, 2017 | 12:03 PM
chillyphilly's Avatar
Did you happen to take any pictures?
Old Apr 21, 2017 | 12:46 AM
dsetter's Avatar
Yes, common problem. I thought my nav system had failed as most audio comes from front door speakers.
Have found this problem in all three cars in my area
Problem always seems to be where the wire is melted into the plastic. Wire soldered from metal and wrapped to write on other side of plastic.
Old Apr 22, 2017 | 12:27 PM
viper1996's Avatar
Any of you finding you have speakers that are out?
Old Apr 29, 2017 | 09:07 AM
JagsteRJX's Avatar
I had to do this on 3 speakers last year.
Old Apr 29, 2017 | 01:08 PM
Zazzy's Avatar
I knew I had a problem a months ago when all of a sudden the sound level decreased. When I adjusted the balance, there was little sound coming from the right. Sometimes, there was sound but the level was alway less than the left side.
Today, I soldered the front right speaker wires. Fixed.
The rear right speaker was unplugged. Plugged it in and it works. I bet that speaker has been unplugged since it left the factory.
