Headlight Bulb Replacement
I need help. when I tried to place the right low beam headlight bulb I couldn't get it to lock into the fixture. I got the bulb seated into the igniter where I think the contacts were lined up properly. I then locked the ring into the ingiter. I can't get the ring to sit far enough into the fixture to twist it into locked position. I remove the bulb and I can get it to lock into the fixture. there must be a simple "trick". Can anyone help?
This is the subforum for the XJ8 (2003-9 X350)
99xk8guy
Sep 29, 2025 10:51 PM
KarimPA
Sep 3, 2015 07:32 PM
