Headlight Bulb Replacement
Old Dec 11, 2016 | 12:34 PM
kevincrompton's Avatar
Default 2005 X Type 3.0 AWD headlight bulb replacement
I need help. when I tried to place the right low beam headlight bulb I couldn't get it to lock into the fixture. I got the bulb seated into the igniter where I think the contacts were lined up properly. I then locked the ring into the ingiter. I can't get the ring to sit far enough into the fixture to twist it into locked position. I remove the bulb and I can get it to lock into the fixture. there must be a simple "trick". Can anyone help?
Old Dec 11, 2016 | 03:30 PM
Partick the Cat's Avatar
You would do better to post in the X-type subforum, X-Type ( X400 ) - Jaguar Forums - Jaguar Enthusiasts Forum
This is the subforum for the XJ8 (2003-9 X350)
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
