Help request - 2007 Vanden Plas ignition key
Old Mar 2, 2025 | 02:42 PM
07vdp's Avatar
Default Help request - 2007 Vanden Plas ignition key
Had to program 2 Jag keys. 1 was a blank key that was cut to the proper profile. 1 was original oem key that needed chip replacement. Chip replaced and everything appeared to be programmed for both keys. Keys in #2 position and all lights, windows, wipers etc function properly; BUT neither key will turn to #3 start position. Any help appreciated. thanks - Dick Otten
Old Mar 2, 2025 | 07:21 PM
hafren's Avatar
Maybe the barrel has a blockage? Check to see if you can open the trunk with the oem key. Did the oem key previously work to turn to #3 and start car or is it a new oem but never associated with the car? Also be sure you have a "6 cut" not "8 cut" key - read the attached to understand Tibbe keys
Ruthietuesdays
Jul 8, 2023 08:00 AM
harlock
Jan 28, 2020 12:45 PM
funracer
Apr 22, 2019 07:27 PM
ditenorio
Aug 5, 2014 10:17 PM
timsalyer
Oct 7, 2013 12:50 PM
