Hood Insulation pad
Old Aug 28, 2019 | 02:50 PM
hafren's Avatar
Default Hood Insulation pad
Has anyone found a solution to a sagging hood insulation pad apart from buying a replacement? I understand the old part # for 2003-2006MY is C2C3725 and the superseded # is C2C32839 for 2007-2009MY which as far as I can tell aren't exactly the same.
Old Aug 28, 2019 | 03:10 PM
Six Rotors's Avatar
You are correct,unless lucky enough to find the original part number. You basically have to "trim" the new part to make it fit reasonably well. The holes for the plastic fastners fit exactly, but you have to trim the edges. I just did this 2 weeks ago.
Old Aug 28, 2019 | 03:12 PM
Terrific's Avatar
I posted what I did with mine under hood liner Sept. 18 2018. Terrific
Old Aug 28, 2019 | 03:29 PM
jackra_1's Avatar
https://www.jaguarforums.com/forum/x...lation-220436/
post #2
Old Aug 28, 2019 | 09:14 PM
Brewster411's Avatar
New part fit my 2005 just fine. No trimming needed.
al_roethlisberger
XJ40 ( XJ81 )
Jun 28, 2018 01:32 PM
rf69
Apr 21, 2016 09:38 PM
Danomar200
Aug 15, 2015 12:14 AM
jaguar jon02
E type ( XK-E )
Nov 17, 2014 01:17 PM
