Horn replacement
Old Oct 4, 2021 | 08:35 AM
aceler8's Avatar
Default Horn replacement
One of my horns has died and i just ordered a replacement from the bay. Can i swap the horns going through the driver's wheel liner or do i need to remove the front bumper?
Old Oct 5, 2021 | 09:05 AM
JCalhoun's Avatar
Yes, you can get at it by pulling aside the fender liner and the radiator under cover. Many of the fasteners on my car were rusted and frozen so half the job was getting the plastic covers off.
Good Luck
Jeff
Old Oct 5, 2021 | 06:59 PM
2018XF25T's Avatar
Old Oct 6, 2021 | 06:39 AM
aceler8's Avatar
Originally Posted by 2018XF25T
Did you ran your Jag in a flooded street? If that is the case more likely, the other horn would also fail soon. Since you are changing the horn might as well install in pair. There is a pair of Fiamm Freeway Blaster for $23.95. Made in USA
No submerging in water...when i purchased the car last year it was clear something was wrong. Only the high pitch horn works, which sounds horrible for such a status car. I purchased a used pair on the bay and will tackle this over the weekend. I'll report back.
mosesbotbol
Apr 12, 2023 12:42 AM
Smonop
E type ( XK-E )
Jan 19, 2021 09:23 PM
jag_guy_2020
Jan 1, 2021 08:08 AM
gsoco
Nov 19, 2015 02:49 PM
Surteco
Jul 13, 2015 02:42 PM
