How do I change the side mirror light cover?
Old Oct 18, 2016 | 03:43 PM
Jgmc's Avatar
Default How do I change the side mirror light cover?
I cracked the plastic cover on the light of the passenger side mirror. Is there a video out there on how to change it. I am visual and like to watch how it's done. Thank you
2008 XJR
Old Oct 28, 2016 | 03:11 PM
Evan Trinh's Avatar
Pop the mirror off first. Look inside you will see clips on the top. Couple flat head screwdrivers to pry it out slowly. New one will pop right into place.
good luck
Old Oct 29, 2016 | 10:29 AM
Sean W's Avatar
Here are the instructions for removing the glass. Apple gentle PRESSURE on the one side and pull on the other
File Type: pdf
Old Dec 30, 2017 | 11:18 AM
Dr John's Avatar
Going to restart this thread and hijack it, too.
I broke the driver's side mirror housing. The clear blinker part is broken and the mirror surround is scratched.
First, where can I get a new plastic lens (is it a dealer only item?), and second, can the surround be replaced too?
Old Dec 30, 2017 | 11:22 AM
Dr John's Avatar
Here are some pics
kmarajh
Oct 19, 2016 02:17 AM
