Jag weird trunk lock
So it started a while back when my trunk lock actuator motor stopped working. I purchased a used one off ebay and because it's a pain to get the motor in and out I hooked it up first and tested it just dangling from the electrical connector. i closed the claw by hand and then pressed the button on my remote and hey presto it opened so i went ahead and installed it. Hey presto now it doesn't.(except with the key. So having to remove the motor I disconnected the mechanical parts and suddenly the remote works again. Reconnect the mechanical linkage and motor goes dead again. So now i am right back where i started only being able to unlock the trunk with the key (trunk release button on the outside doesn't work nor the inside button or remote. I can't figure out the logic why the electrical motor works perfectly until i hook up the mechanical linkage!
There is no sound once I bolted it in place. I am wondering if it could be an earthing issue? Looks like the motor casing is designed to not touch the vehicle body. Maybe part of the linkage is touching metal somewhere.
