KEY FOB
Old Jul 16, 2024 | 11:44 PM
Bob Hornby's Avatar
Default KEY FOB
My key fob (XJ6 2006) has stopped working, a new battery had not fixed it. If I purchase a new fob online and have it cut by a locksmith can I program the remote myself or do I need to have the locksmith do it? Also, any recommendations on which online supplier to use?
Old Jul 17, 2024 | 04:38 AM
Jaroslav Záruba's Avatar
Which part of it does not work?
The key fob has two functions:
1) remote, this is affected by the battery
2) transmitter that works along with the metal blade to start the car, I am not convinced this one needs a battery
If only the later does not work, you can buy just this part (make sure to get the proper frequency: 315 MHz for US, 433 MHz for most of the other markets), and keep the part with the original blade+transmitter.
Old Jul 17, 2024 | 04:41 AM
My car is of US spec, and I only needed to replace the "remote" part (1 of the 4 buttons did not work)
this is what I bought: https://www.ebay.com/itm/163502766321
...and programmed it myself following TTG guide:
Old Jul 17, 2024 | 06:04 AM
ctsemicon's Avatar
You may find the attached useful.
Old Jul 19, 2024 | 12:32 AM
Bob Hornby's Avatar
Thank you very much Jaroslav and Ctsemicon for you replies and the video. I am now quite confused and unsure where to go now. In the video the guy mentions that the one he bought on line had the incorrect transponder. All the 4 buttons on my remote do not work any more, I have tried two new batteries with no luck. The mechanical key opens the door and starts the engine OK.
Old Jul 19, 2024 | 05:28 AM
IMO, in your case you don't need to care about the transponder, yours is OK, otherwise you wouldn't be able to start the car. (Here's me asking about the transponder couple months ago. Note that I was mistaken thinking some of the key-fobs don't have the transponder.)
In your situation I'd do exactly what I have: buy this thing, open your key-fob, toss away the half with remote/buttons from yours and stick in this new one. (I.e. put together your half with the blade/transponder and the new half with the remote/buttons.)
Then you just need to introduce the new remote to the car, as demonstrated by the guy from TTG.
Old Jul 22, 2024 | 09:32 PM
Bob Hornby's Avatar
Just to be sure, can it be confirmed that my frequency for the remote should be 433.92 MHZ. My X350 is an Australian import.
Old Jul 23, 2024 | 03:51 AM
I suspect the 433 MHz was exclusive for Europe. (I see in my earlier post I implied USA/315 was the special one, my bad. It seems more likely Europe/433 is the one weird market.)
I am like 75% certain the actual frequency of your car is shown somewhere in the SDD.
Also the frequency is very likely identical to the one your car's TPMS uses. Thus guys in a tire-shop should be able to verify this for you.
I realize none of these are super-solid answers.
Old Jul 23, 2024 | 05:49 AM
ctsemicon's Avatar
Look inside the Key Fob Doc I attached in previous post. It lists which variants are 315 mhz and which are 433 mhz. Just pop open the original Fob, and you will see on the first line of printing (on the button half) something like "1X43-15K01-AE" . The key (pun intended) is the last two characters. All the "A?" variants are 315. Note he statement Key Fobs transmit on 315.0MHZ for US market except BD series which are on 433.92MHZ for Europe market – Therefore, for the imported Jaguar cars only 315.0MHZ remotes will work on your car:
Old Jul 23, 2024 | 07:31 AM
Bob Hornby's Avatar
Thank you very much for that info ctsemicon The number on my fob is 1X43-15K801-BG so that means mine is a 433.92MHG. I can now go ahead and order on on line and program as per the video that Jaroslav posted.
Old Aug 9, 2024 | 11:29 PM
Bob Hornby's Avatar
I am becoming very frustrated. I ordered some new key fob parts on line, a PC board (433 MHZ) and the cover with the buttons on, my car is Australian so I am assuming it is European frequency. However I received the complete key. I went through the pairing process i.e.
Open driver’s door
Pull headlamp flash and hold
Insert key and turn to first position (accessories)
Release flasher stork immediately
Flash headlamp 5 times, at this point the red LED flashed and beeped.
Push any button on the fob 5 times.
The key fob still does not work, I went through the process several times with no success. I have put a new battery in the fob.
Because I didn’t receive exactly what I ordered I thought that just maybe it was the wrong frequency (315 MHZ)
So I went back to the internet and ordered just a 433 MHZ PC board which was duly delivered. Still no success. Could it be that there is an issue with the car, rather than the key fob ?
Old Aug 10, 2024 | 12:26 AM
meirion1's Avatar
You have to flash really quickly
Old Aug 10, 2024 | 03:10 AM
Pete M's Avatar
Hi Bob,
There are lots of videos on YT that demonstrate the process. Sometimes watching it a few times makes it all click. I had to do it several times before it worked, and I think I wasn't flashing the headlights fast enough. The process in the pdf guide above is correct. This YT clip seems as good as any.
My car is ex-Japan, so has the 315MHz fob. The key I bought from AliExpress is still working fine after about five years, so I have no complaints about quality.
Pete M
Old Aug 10, 2024 | 05:36 PM
Bob Hornby's Avatar
I have re-watched the video and re-read the pdf. I am flashing the lights as fast as I can and certainly not slower than the video. I have changed the battery again (in case it was a dud) But no luck. I am getting ONE beep during the flashing. (the pdf says if TWO beeps are heard then there is a problem). I get THREE beeps after finishing the process. The reason I would like the remote to work is that I am old school and like to open the passenger door for wife to enter before I enter.
Where do I go from here?
Old Aug 10, 2024 | 08:21 PM
meirion1's Avatar
Maybe stop after one beep?
One beep indicates process is complete
Old Aug 11, 2024 | 08:18 PM
Bob Hornby's Avatar
Thanks Meirion
I have tried that but no luck. I think I will have to admit defeat on this one, which makes me very disappointed.
JaguarXJL15
Jun 21, 2025 02:21 PM
Tracee
Jun 3, 2022 05:59 PM
karenh
Sep 3, 2020 03:59 PM
95Leaper
Feb 19, 2017 08:32 AM
