The last few I have heard a very slight knocking sound coming from my front end. It only happens on local roads at low speeds. It has been getting louder as the days go on. Any ideas perhaps bushings etc. please help!
Check your sway bar end links. I found mine were not fully tight and had noise similar to yours. You will need an allen wrench and box wrench for the top nut and bolt and a socket and rachet for the bottom nut. Good luck.
