Oil pressure warning light
Old Mar 26, 2024 | 03:13 PM
feniks138's Avatar
Default Oil pressure warning light
Hi guys!
I am having a problem with the oil pressure warning light at the instrument cluster. For the last two years when I was starting up the car I had the oil pressure symbol light up before a cold start-as expected but never coming on anymore when doing warm starts. Starting this winter and so on I have never seen the light come up on the instrument cluster at all. I've mentioned it to the mechanics while they were fixing a transmission leak I had the other day but they say that they have tested the oil pressure switch and everything seems fine and just to move on and forget about that light (I dislike that answer...). I've put the instrument cluster into test mode and I do confirm the bulb is operative. Is there anything that I can do without a lift to confirm that the pressure switch is indeed OK? Are they prone to failures? Thanks!
jindra
Feb 23, 2023 12:08 PM
dmukic
Oct 26, 2019 10:49 AM
philwarner
Jul 13, 2019 06:20 PM
Greg in France
Apr 5, 2019 04:19 AM
ocduff
Sep 1, 2009 10:32 AM
