parking sensor
Old Mar 12, 2013 | 09:17 AM
Saratogarider's Avatar
Default parking sensor
My 04 XJR got a new battery and now my parking sensors are showing a fault. 3 second tone and light on starting. Whats the fix? Thanks
Old Mar 12, 2013 | 10:06 AM
Welcome to the forum Sartogarider,
I've moved your post to the model tech section for a better response.
We always like a little foreplay here before getting down to business, maybe you can post an intro in the new members section?
Old Mar 14, 2013 | 11:18 AM
xjrguy's Avatar
Really need a bit more information, my friend.
Do you mean the tone occurs every time you start the car??
Is the light you refer to in the Park Aid switch in the roof console??
Does this car have Front and Rear Park Aid, of only Rear Park Aid??
Generally the Park Aid indicates a fault by sounding a solid tone for 3 seconds when the shifter engages Reverse, not when starting the car.
I would start by doing a reset of the car again. Disconnect the battery for a few minutes and then reconnect it quickly and cleanly. Then reset the window one touch and try the Park Aid again.
Good luck!
Old Mar 15, 2013 | 08:51 AM
Hi Steve, You are of course right. It is a 3 sec tone when put in rev and the light comes on the overhead console switch. I disconnected the battery and noticed that only the passenger rear window goes back up with one touch. I am unfamilair with this cars "one touch" setting(s). The parking sensors, front and rear, are the same. Not working and showing fault. Thanks a lot for the help. Scott
Old Mar 15, 2013 | 10:46 AM
psg's Avatar
psg
I also have park sensors not working but I get a warning in the display that says the fronts are not working and the whole system shuts down with the 3 sec warning etc. I tried listening for the clicking but don't hear anything front or rear because I assume they are shut down by the parking module when they sense a fault. Is there anyway to determine which sensor has failed? Hope I'm not hi-jacking the thread.
Stu
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
adam699
Sep 12, 2015 05:32 PM
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
