Pulsing Lights
Old Oct 15, 2017 | 06:52 PM
icedragonB's Avatar
Default Pulsing Lights
I've got a 2001 XJ8 with a pulse in the lighting system. The dash lights will phase from bright to dim in tandem with the sound of the engine. If I turn on the headlights they too will surge in sync with the sound of the rotation in the engine, but the headlights do not need to be engaged to see the effect. We have checked for clean grounds throughout the engine compartment and cleaned the ground where the engine grounds to the body beneath the passenger floor, checked the pulleys for drag, replaced the belt & water pump (for other reasons) and all four o2 sensors. The alternator is just over two years old (new battery at the same time) but this problem existed mildly prior to the alternator change. The only thing we have been able to do that alters this situation is removing the 5 amp fuse that is related to the alternator. When the engine runs straight from the battery, the lights are bright and steady. As soon as that fuse is put back in place the surge immediately starts again and lights pulse. The fuses are good. We also checked the cables running from the alt to the starter & starter to battery and don't see any indication on the amp meter to indicate that these might be the cause of the problem. The amp meter on the battery terminals reads 12.30 with the car off, with it running it's between 13 - 13.66 with the occasional jump to 14.
Any ideas on what might be causing this that we haven't already ruled out would be greatly appreciated!!
Old Oct 15, 2017 | 11:57 PM
woox4's Avatar
This forum is for post-2003 XJs, try this one https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
