Rear bulb failure modul or body control unit
Old Nov 21, 2021 | 11:26 AM
jean HJ's Avatar
Default Rear bulb failure modul or body control unit
Hello
I have some problem with the rear lights indicator as well registration light.
I thought the indicator Stalk were defect but wasn't after using diag it comes up that the module is defect. I bought one from a diesel which didn't work because the fuel pumps didn't work.im not sure if I can use only one from a v8 or do they need all re programmed to your specific car vin number.i got as well the info that the module get wiped by turning on the ignition when it's not reprogrammed before.can I reprogramming with mongoose?
When I have a look on the module alll ads say usable from 2003 to 2009 other specilast mean 350 to 358 are difference which I can't believe when it's a bulb failure module
May someone had similar issues any info or tips I would appreciate
Cheers Jean j
Old Nov 21, 2021 | 03:26 PM
meirion1's Avatar
Open up the module and look for any damage eg
moisture
leaking components
bad solder joint (with magnifying glass)
dirty or bad wire connections etc.
Old Nov 24, 2021 | 08:35 AM
hisport's Avatar
See my response to your previous post
JensenHealey
XJ40 ( XJ81 )
Sep 21, 2020 05:57 PM
mibman2003
Sep 22, 2018 11:15 AM
95Leaper
XJ40 ( XJ81 )
Apr 11, 2017 01:00 AM
newheart8
Aug 16, 2015 07:23 AM
pjrawlings
Jun 27, 2013 06:53 PM
