rear heat and a/c vents
Old Apr 29, 2023 | 11:55 AM
oldole's Avatar
Default rear heat and a/c vents
How do I get rear vents to work, blow warm or cool air.
2007 Jaguar xj8
Old Apr 30, 2023 | 03:10 AM
Pete M's Avatar
2007 Jaguar xj8
Hi oldole,
Does your car have 4-zone aircon?
If so, the control should look like this...
4-zone Rear aircon control
To switch the rear aircon, go to the main climate control page on the screen. Go to OPTIONS, and there are the various controls for the rear aircon.
You can set it to ON, OFF, 'match driver' and some others.
If you don't have rear aircon, then the back and front should be the same temp etc.
Pete M
Old May 1, 2023 | 08:32 AM
wfooshee's Avatar
Yes, as above. If this control panel is not present, then the rear vents are simply extensions of the front system, and the rear passengers can only open or close the vents; they don't have separate control of the system.
If you do have that control panel and the system doesn't work, then, um... I don't have an answer for you.
taperguy
Dec 30, 2021 05:08 PM
joey4420
Nov 26, 2013 03:59 PM
Fyrplg
Jun 14, 2012 02:26 PM
jag79
Mar 19, 2012 10:40 AM
stran0020
Jul 1, 2010 08:59 AM
